hi i currently have a n80 my contract expires 11th may and i want to upgrade to n95 does the software that i have installed on my n80 work on the n95? i have the .sis & .jar intallation files and serials.
Chris
Chris
everything will work but you will need to buy a micro sd card as n80s was a mini, so you cant jus transfer the card from one device to the other
menhel wrote:everything will work but you will need to buy a micro sd card as n80s was a mini, so you cant jus transfer the card from one device to the other
It'll work providing the software serial number isn't based on the phone IMEI. I've got 3 progs that relate to the phone's IMEI so I can't use them. To be honest I never used those programs much on my N80 so I'm not too worried but some companies will insist on you buying the software again for the N95 as you're using the software in a different device.
