Hello, i have been a windows mobile user for a number of years now, but liked the look of the N95 so decided to try and come back to Nokia. So far everything is good and i like it but i use the calendar in my windows mobiles for eveything date related. I frequently have repeatable tasks which are automatically regenerated by the software. i use Papyrus on my windows Smartphone so i thought it would just be a case of me installing the symbian version however this function does not appear to be present in this version. Can anybody recommend a good calendar application that will give this facility.
Thanks in advance
Paul
Besides the built-in Calendar and Papyrus, I only know of AquaCalendar, which you should be able to find in the software section: http://www.allaboutsymbian.com/software/
Whats wrong with the built in Calendar ? I love the fact you can synch it to googles one ...
Another good thing about the built in calendar is that if you have the active standby on you see what's coming up on your standby screen.
Hi everyone,
I have an E61 and personally love using Papyrus over the built in calendar.
We've just released a new version - 1.2.13
Papyrus now supports right-to-left languages such as Hebrew and Arabic.
Check it out here:
http://forums.sbsh.net/index.php?showtopic=17449
