I got a memory card from my friend and when i tried to use it on my nokia 6670 it asked me for a password and my friend didnt know what it was and neither did i, so i tried to look for ways to get the password and i donwloaded feexplorer on my phone but i cant find the memory card folder on the c drive of the cellphone so i cant see what it is eitehr and it wont let me reformat the memory card without me knowing the password. Could anyone helop me? the help would be really appreciated 😃
How do i unlock or reformat my memory card?
I'm afraid there's nothing you can do if you forgot the password. You can throw that MMC in the first thrash can.
I had a very similar prob with card in my 7610...found a little prog that gave me the password..not sure if it willwork with ur model but worth a try.
It works only if the MMC password was set on the phone in which you install the app. Try to format the MMC in your friend's phone, maybe it will remove the password.
my 7610 had a rs-mmc and i forgot the password. i have done anything possible to solve this concern but all of it didn't worked. i also downloaded the fexplorer but didn't find the mmcstore file/folder. i also tried the mmcpwrod reveral but it also failed. i can't even reformat the mmc w/out the password to unlock it. PLS help ME! thanks in advance!:con?
