I'm new here so a big HELLO to everyone 😉
I'm having trouble with MMS on T-mobile. When I first got my N95 everything was fine and I could send MMS. Now, everytime I try to send an MMS it fails and then tries to resend it every 10 minutes. I have done the setting wizard thing 3 times and this doesn't fix the problem. Neither Nokia, or T-mobile have MMS settings on their site for the N95. I bought the phone sim free, so it isn't on a contract. The strange thing is that I can receive MMS. Can anyone share some of their wisdom? Thanks in advance.
I'm on SIM free T-mobile too. A few things to try:
- If you're on pay as you go check you have credit for an MMS message
- Turning 3G off (so it uses GPRS instead) to see if that works for MMS sending
- Try using something else that uses the same access point, eg Web browser
- Try setting messaging up to use the other access point for MMS messages
- Try phoning T-Mobile to check there's no 'block' on your account for outgoing connections
If all these things fail, private message me the settings you're using and I'll compare with what's on mine.
Hopefully one of these things will sort it. 😊
Good luck!
Steve
Thanks Steve. I'll try everything you suggested 😊
