Do I need to buy tom tom or do i just install maps pls. help thanks in advance
Gps Question
It depends what do you want? Maps from Nokia, have a pay fee to have voice guidance. TT, is all in one package with need of external antenna, because for now, don�t use the internal GPS from N95.
As Nj7 says. If you just want to use GPS, you can download maps for free. If you want voice navigation though, you have to pay, though it is cheaper than buying tom-tom. Plus you would also need an external receiver for TomTom as it does not use the internal GPS yet - I'm sure they are working on it.
ok i'll just download maps for now, i'll wait for the tom tom that will be available for n95.
thanks guys. oh yeah where can i get free map?
For me, and a lot of others, the maps came free with the memory.
If not, I'd suggest hooking up to a WiFi point and download it through that so that you avoid paying any download fees.
