I've installed it on my P800, the eMame itself run perfectly, but when I tried to run a free game from mame.dk (polygame.zip/robby.zip) - the result is a popup : KERN ERROR-3, or sometimes KERN ERROR-4.
Anyone got the same experienced? need advice 😞
eMame for P800 error?
I got the same errors :roll:
but i get JR pacman to run on it at least 😃
Hopefully peter can check what can be wrong and maybe release an updated emame?
I've sent some error reports to Peter, but so for no response yet.
There are tons of games on the "working" list that does not work + some applications that create an error - will force you to shutdown and restart the phone, since it overwrites the top menu and sits there waiting for a keypress. ;-( and there the "virtual" keys does not work... (Any key is NOT any key 😉
