Import opml file?
2 replies · 2,185 views · Started 21 April 2007
So let's say you got your opml file onto your phone via bluetooth.
With my N80 I could open that directly in Podcasts but apparently now it opens in Notes and when I save I'm just told it saved the attachment but it doesn't look like I have access to the location where I saved that file.
So how with the N95 do you import your Podcasts.opml file which you exported from itunes your favourite RSS podcasting program.
You should be able to use the import option in the Podcast application itself.
In the Directories section choose 'Import OPML File'.
Yeah that isn't the problem. The problem is that once you loaded it into Messaging it only lets you save it via Notes in an area that Podcasting cannot see. So in my case I had to move it to a location that Podcasting can see.
Unnecessarily complicated.
