Lo again all. Just wanted to ask, how quick does the media screen appear after pressing the media key? Mine takes just over 5 seconds and I was wondering if this was normal or whether my memory card is the reason (it's a standard 2gb sandisk card, not one of the quick ones). On my N80 the media screen appeared instantly but the N95 is slow, so slow in fact that I can go into the regular menu and select the app I want to run before the media screen even comes up, which kinda defeats the object of having a screen full of your favourite app's icons on it.
Oh, and just in case there's some confusion as to what I mean when I say the media screen, it's the screen/menu that comes up when you press the media key (the one that you set up with your fav programs icons on it).
