A Q to GPS Experts
4 replies · 3,592 views · Started 21 April 2007
Hello everybody,
I bought the N95 a week ago and this phone is amazing 😎 .. the GPS feature is outstanding and I am using it here in Qatar and its so accurate!! :icon14: the idea of having this phone where ever u go and be able to navigate your way is really cool..
My question to the GPS experts is how can I change the coordinates format from degrees ddd.dddd (default) to dd.mm.ss more commenly used format?
Any thoughts will be helpfull!! Thanks
aldosari wrote:Hello everybody,
My question to the GPS experts is how can I change the coordinates format from degrees ddd.dddd (default) to dd.mm.dd more commenly used format?
I installed Mobile G Maps .. for a couple of reasons .. the one that comes with the N95 isn't that high res for my location and it has a couple of placename spelling errors. It also has the Hybrid maps .. so you can see a satellite image of your location.
Anyway .. I tried to find the GPS coordinate change in the default mapping application, doesn't look like you can do it.
In Mobile G Maps .. its in settings / GPS Setup / Other settings .. options are
DD`mm'ss"
DD`mm.mmm'
DD.ddddd
the ` is actually the degree symbol but couldn't be arsed finding it 😃
so hope that helps!
seki wrote:I installed Mobile G Maps .. for a couple of reasons .. the one that comes with the N95 isn't that high res for my location and it has a couple of placename spelling errors. It also has the Hybrid maps .. so you can see a satellite image of your location.
DD`mm'ss"
DD`mm.mmm'
DD.ddddd
so hope that helps!
seki.. thanks for the info my friend..
I already have Gmaps on my device.. I tried changing the coordinates but i couldnt find OTHER SETTINGS under the Settings/GPS :con?
also a disadvantage of Gmaps is that u have to be connected to the internet to keep seeings the maps.. the default mapping sofware is more flexiable where u can store desired maps direct from the PC or ur wifi network ..
anyway.. thanks again buddy
Gmaps will have offline mapping in a "month or less". I.e. you can download the maps on a PC first them copy to the phone/memcard and you wont have to have the slowness and expense of downloading them over GPRS/3G all the time 😊
autopilot wrote:Gmaps will have offline mapping in a "month or less". I.e. you can download the maps on a PC first them copy to the phone/memcard and you wont have to have the slowness and expense of downloading them over GPRS/3G all the time 😊
These guys have already done what I was re inventing about an hour ago!
Run a mobile web server on your N95 .. put all the mapping info into it .. configure your mobile mapping app to look on the local web server and presto! independence.
http://discussion.forum.nokia.com/forum//forum/thread/100818/
or better yet .. http://raccoon.openlaboratory.net/RaccoonOnMap/doc/setup.php
Enjoy! 😃
