task manager & recharge battery problem.
1 replies · 4,240 views · Started 07 January 2003
i have installed task manager,
power off 7650,
try to recharge battery.
when attach charger, phone power up and display "nokia", i see "task manager " run.
open-close keypad and label "sblocca" (in italy, sorry 4 bad enghlis) appear.
battery bar (status) dissapear on top dx, and on top sx i have signal-bar.
light power on and screen white.
now i have disintall task manager and pone work good.
[quote="Nemis"]i have installed task manager,
power off 7650,
now i have disintall task manager and pone work good.[/quote]
try installing it again, that's the only thing i can suggest and see if there's a difference. if the problem persists, contact psiloc. http://www.psiloc.com/ 😃
