what firmware is this ??
9 replies · 1,677 views · Started 22 April 2007
hey im upgrading the firmware but can u tell me if this is 3 firmware or genergic ??
4.0623.0.41 ?????
i have changed the producy code now and run nsu but it says i have the latest firmware ??? is this ok ??? im gona re-install it soo fingers cross
andrew.w wrote:i have changed the producy code now and run nsu but it says i have the latest firmware ??? is this ok ??? im gona re-install it soo fingers cross
Make sure you change to N80 internet edition Generic .. I cant remember the code that will suite you best
well i just flashed it there and every thing went gr8, i found out why it didnt update last time it was beacuse i hadnt writen the code properly !!
andrew.w wrote:well i just flashed it there and every thing went gr8, i found out why it didnt update last time it was beacuse i hadnt writen the code properly !!
Ah yeah, getting the code right devo helps! :tongue:
You can reinstall the f/w version as many times as you need to... Ive had to do it 3 times now.... just testing... so no worries...
good to hear it all went well. 😊
hahaah ah well. 😊 Its done now... so you should be fine... UNLESS you changed the product code back again.
