Finally managed to change the product code (after realising that NSS doesn't work on Vista!) and phoned both CPWs in my area which are apparently nokia service centres to be told that they haven't been given any firmware for the N95 so they can't reflash it!! grrrrr 😞 I was told that Nokia are due to release one for public use anytime now so I can take it in then and they can do it!! Doh!! I know that!! 😞 so looks like I'll have to put up with my crappy O2 stuff fopr a bit longer 😞 xx
CPW don't have any firmware apparently!!
BasiBabes wrote:phoned both CPWs in my area which are apparently nokia service centres to be told that they haven't been given any firmware for the N95 so they can't reflash it!! grrrrr... so looks like I'll have to put up with my crappy O2 stuff fopr a bit longer 😞 xx
You can DIY re-flash your N95 tonight if you can't wait for CPW.
The instructions are in my post on page 1 of the following thread... http://www.allaboutsymbian.com/forum...ad.php?t=58684
P.S. Don't know if Phoenix works on Vista... let us know if it does.
dez_borders wrote:You can DIY re-flash your N95 tonight if you can't wait for CPW.
The instructions are in my post on page 1 of the following thread... http://www.allaboutsymbian.com/forum...ad.php?t=58684P.S. Don't know if Phoenix works on Vista... let us know if it does.
Link doesnt work!
Nogimics wrote:Link doesnt work!
I have tryed phoenix before and its a bit scary to try, best wait for NUS to get it, should not be long now.
My apologies, try this one (see my post at 16-04-2007, 09:14 PM )
