hi
i have been experiencing playback audio video sync problem on the n95. the encoded files play fine on media player on the laptop but when i transfer the file to the phone the video playback laggs behind the audio. if i pause the video its back in sync again and then gradually becomes out of sync. its really frustrating!
also ive only got a trial version of mobile DVD installed on my phone. is there a free version anywhere???
hope someone can help.
DivX files playback
Probably because those files are meant for PC playback you should encode them with something like 3GP Converter.
Try:
SUPER ©
converts many video file types to 3gp format
free software and user friendly
There's an add-on for nokia suite which will convert the Divx as it's transfered to the phone - will be trying it tonight for the first time.
please let meknow how it goes??
The Nokia thing is rubbish. First time it just hung, and the second time it produced a rubbish picture with the sound out of sync.
I used Super in the end and its worked very well indeed. Loads of settings for frame rate and screen aspect.
One question for anyone who has used it - in Super, is there an option to encode a 16:9 video slightly zoomed in so you loose the edges of the picture but so it fills the whole height?
