Bluetooth stereo headsets Pros and Cons
0 replies · 3,708 views · Started 24 April 2007
I have tried out the Sony Ericsson HBH-DS970 with my N95 and have exprienced some issues:
- Tags are not shown in the display, maybe the nokia music converter is messing up the tags. I will try to not convert the mp3 and see if it works better..
- As explained earlier in a similar thread there are some pauses in the transfer that occurs from time to time.
- Volume, the headset cannot deliver enogh volume to listen on music out in environments with some disturbance like the street with normal traffic.
- If u get a call while listen to the music and answer it with the button on the left and then press the button to close the call the telephone get hanged up and reboots itself, takes more than a minute. One do not need to press that button to close the call just let the "other" caller close the call and the phone will disconnect automatically and then the music comes back.
- If u play music from your library on normal or random play you cannot use for the next and back buttons this only works if u play a playlist. Excessive pushing on these buttons will cause the telephone to hang and reboot itself.
Assesment: Very nice look and feel of the headset, sound ok. However due to the problems mentioned above I will trade this one in.
Have anyone tested the HS-12W headset from Nokia with the N95? Please enligthe us...
