3250 - Request not Completed
5 replies · 8,480 views · Started 24 April 2007
Just wondering has anybody had any problems with the Nokia 3250 using shortcuts i.e. If i want to check my credit i type*100# etc.
For the last few months these will not work for me and i get an error message saying request not completed.
Anybody any similar experiences, if so did you get it working again?
Between the time it last worked, and no longer works, have you changed your network operator/SIM card?
If not, what does your network operator's customer service say about this service?
i think io know what he means, my 3250 now shuts down and restarts if i try type '*#10#', now i just call 4444 and do it that way, also sometimes after sending a text i will get a box saying 'message' and then my credit, i think that maybe dialing '*#10#' on the 3250 may enable and disable this...
bimboman wrote:i think io know what he means, my 3250 now shuts down and restarts if i try type '*#10#', now i just call 4444 and do it that way, also sometimes after sending a text i will get a box saying 'message' and then my credit, i think that maybe dialing '*#10#' on the 3250 may enable and disable this...
I believe there is nothing wrong with your handset. This is your Network operator's problem. Question them. Try putting your sim card in other device and check if it works.
squiggy wrote:Just wondering has anybody had any problems with the Nokia 3250 using shortcuts i.e. If i want to check my credit i type*100# etc.
