I think it may be an idea to have some kind of buglist for the new and improved firmware. So this is the first step, if you want to contribute to the thought and have a bug, please simply post a reply. If you read about a bug in this thread that you solved, don't hesitate to post it as well...
Bugs found so far (by me that is)
- Display will not show caller/callee when on call [it displays "Call 1", where other Nokia phones keep showing the name, this is especially usefull when a seccond call is knocking on your door]
- Datasheets saved as Excel 97 or 2000 can not be opened in Excel
I get the message "Note not found" when I try sending a ringtone. It seems that other people gets the same message but with other apps... Nokia Service Point doesn�t know why...
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
This is not true, download the latest ringtone player for 4.13.....
reg. Excel sheets error, any solution you have found? Mine too, 'cant open excel sheets converted to windows... hmmm wonder why?
I ran into the excel problem the other day, but assumed it was a problem with PC Suite not converting properly. Hopefully they can fix this one with a downloadable software upgrade.
The problem I have noticed (not just with 4.13) is that the Web Browser cannot cope with pick lists. e.g. If you go to the Nokia site and try to select the 9210 from the phone list. If anyone knows a way round this it would be useful by the way.
Zuber
The problem with the selections is because people are making use of a *feature* that found it's way into IE, that lets you send data just by changing the selection in the selection box. IThis has since been adapted into Netscape/Mozilla and Opera etc, but wasn't originally part of the W3Cs spec for the object. Hence some web browsers still don't function like that.
The correct implementation is to have a "Go" button as you can see at the bottom of this page to choose the forum
Unfortunately use of WYSIWYG like M$ GashPage have led to many sites not working properly.
The error that I got is
>application AppArcServerTread
>Reason code FSCLIENT panic
>Reason number 24
I wrote it also somewhere else, but it seems Ok to me to have it in this buglists.
It comes back randomly now, e.g. when downloading messages or using smallbase. Maybe a memory problem?
Frequency once in three days?
Huib van den Oever
The
"Call 1" "bug" is not a bug, but a design choice.
Think When you are using the phone you have the display pointed away from your head.
Do you necessarily want the person next to you knowing who you are calling?
The "Call 1" can be a design choice, and I can imagine it for ongoing calls, but it is very unhandy when a second call is presented, because you do not know who is calling you. This also goes for use in a car kit - when nobody can see the display.
So if it is a design choice, I'd like to make that one myself. Make it an option, I'd say.
NTOO
one small problem i detected,but quite an imp for people who want to screen their calls. sometimes when i receive calls, i dont get the "MUTE" opetion, & sometimes i dont get the option but if i press the buttonwhere it usually come, it works, i really like this opetion to screenmy calls.
has anyone else noticed this problem.
other than a small few problems, i"m really like the 9210 with the 4.13ver. its xalant.
ciao
gaurav
Now you mention it... I have the same problem, only 'answer' is shown as an option. I then just press the red 'end call' button and that helps, but when I am already in a conversation this is not an option.
NTOO
