POI icons
2 replies · 1,932 views · Started 25 April 2007
I doubt it, but has ANYONE figured out how to "hide" Tomtom POI icons from showing up in the gallery yet?
Thanks.
From another thread on this forum I found Y-browser, with it you can set any file's properties to 'hidden'.
Once a picture is set to hidden it is no longer is displayed in the Gallery..
Download the latest version (currently v0.80) from http://www.pushl.com/
The only downside I found was I couldn't 'mark' all the files and change them all together..
Took a while but it's done now.. I don't know if you loaded your SD card in a card reader whether you set the hidden property on you PC..
Good luck
