mmc
1 replies · 1,164 views · Started 25 April 2007
Hi
I have a memory card for N70 it is requesting for the password which I never created. Can someone please give me advice I do not want to format the memory card because I have important info in.
Thnks
If you can still open and view the files in the phone, backup everything you need with PC Suite and then format the MMC. If you can't, try to find mmcstore file under C:\System and view it, last digits are your password. If this file is also missing, you can throw that MMC in the first trash can you find, because you won't be able even to format it.
