Nokia 6600 to E61 data transfer!!!
2 replies · 2,299 views · Started 25 April 2007
I just got myself a new E61 with a 2GB mini-SD card. Now I find that the PC suites on both phones are not compatible! How do I transfer my contacts, calendar and other data from the old one to the new?
Any suggestions???
As for the contacts & calendar entries, you can synchronise your 6600 with MS Outlook. Then you can synchronise your E-61 to have the contacts & calendar entries into yor E-61. If the PC Suite is different, after synchronising your 6600 install the latest PC Suite to synchronise you E-61. Hope this helps.
