Nokia n70 no valid gps signal
2 replies · 2,049 views · Started 25 April 2007
Dear All,
I have one nokia n70 with tomtom 5.2 + antenna bluetooth GR 102 from tech but unfortunately the mesage is allways the same (no valid GPS signa).:frown:
Can you help me?
Many thanks
Cap
Does the Bluetooth GPS receiver work with some other phone?
Have you contacted TomTom support regarding your problem?
Disable traffic in the first instance. Turn off TomTom prog and GPS and then from BT menu delete the pairing with the GPS.
Turn on GPS and wait for indication from it that you have a satellite lock. Then run TT and wait for TT to indicate that it has found the GPS via BT then pair from within the prog.
If you still don't get indication of having found GPS device then from TT prog press 56661 and make sure you are configured to use 'other' BT GPS. If you still don't get some blue bars on the status then you probably have a hardware fault, but not necessarily.
