When plugging in my N95, it is immediately detected and connected correctly and PC Suite works fine.
However, the USB connection is not listed in the 'Safely Remove Hardware' list unless the USB connection mode is set to 'data transfer'.
The net result of this is that when I unplug my USB connection (without being able to safely eject it first), PC Suite fails to detect that the phone has been disconnected and still shows the phone as connected.
If I subsequently reconnect the N95 via USB, the phone is no longer detected and rebooting Windows XP is the only way to re-establish the connection with the phone.
Anyone else had this problem? :con?
Steve
