Sorry for starting another thread guys, has anyone noticed that when you slide the phone up, the keypad sometimes does not light up ? Why is this so ? Is it something to do with a power saving option that needs to be set ?
Thanks once again
Thanks once again
if its the same on the N80 it sense the amount of light on the phone and if you're in a dark place it will light up automatically and if theres enough light it wont!
Keydogg wrote:if its the same on the N80 it sense the amount of light on the phone and if you're in a dark place it will light up automatically and if theres enough light it wont!
Yepp, it's a sensor. It's placed left of the camera on front. It also controls the light in the display and can be adjusted. More info? => Read the manual... 😉
And here I thought it was a fault LOL 😊 Thanks very much guys, I feel much more relaxed hehehe
