I installed Worms 3d forts on my N95 but it wouldn't work. When I click on it nothing at all happens, no error messages or anything. So I tried to delete it by pressing the C button but it won't delete, just says Removing failed. So I left it and installed another game, Penguin strike. Now when I click Worms 3d the penguin game starts and I still can't remove Worms. Anybody got any ideas?
Can't remove Worms java game
millski wrote:I installed Worms 3d forts on my N95 but it wouldn't work. When I click on it nothing at all happens, no error messages or anything. So I tried to delete it by pressing the C button but it won't delete, just says Removing failed. So I left it and installed another game, Penguin strike. Now when I click Worms 3d the penguin game starts and I still can't remove Worms. Anybody got any ideas?
Ok, after searching online for 3 days and getting nowhere I discovered that to remove applications (games/themes too) that were causing me similar problems, all I had to do was re-install them. 1). Turn the device off and then on again (this will ensure that the game isn't running). 2). Re-install the game... the N95 will tell you that the game already exists within the device and will ask if you want to replace it. 3). Say yes, it will then ask you if you want to save existing application data 4). Say no. Without opening the game go into app manager in the tools menu and remove the game. Done?
sorry posted twice i think...
Worked like a charm! Thanks tccorp':icon14: Now if only there were some more N95 compatible games worth playing...
Glad it worked for you. Somewhere on here I read that you can expand the old games so that they fill the large n95 screen. I haven't found a way yet but if I do then I will let you know.
