My windows vista doesn't recognize N95 when connected as mass storage drive.
When i connect the phone, vista looks for drivers that doesn't found...
Any hint or solution?
I have the last version of pc suite installed.
N95 and mass storage mode with Windows Vista
Apart from the error message the PC suite gives you.
I'm using Vista Ultimate - I put the phone in "Data Transfer" mode .. plug it in - my PC is a pretty standard Shuttle .. it just plain works.
So sadly looks like your PC .. have you tried a few different ports? They aren't necessarily equal. Have you tried it on another PC?
I use and recommend TuneUp - there's a new version for vista - this will fix "windows" issues .. but to me it sounds like a hardware/driver issue.
That is wired... it seems it doesn't find any driver, it starts to search on windows update and the it doesn't find anything...
I've the last version of PC Suite
Danielem wrote:That is wired... it seems it doesn't find any driver, it starts to search on windows update and the it doesn't find anything...
and tell vista to use that driver .. it might complain .. but it'll go.😊
seki wrote:and tell vista to use that driver .. it might complain .. but it'll go.😊
Ok but WHICH driver? 😊
I think its part of the PC Suite Install .. that means 6.83 (the vista version)
the 3 drivers installed are
PCCSWpdDriver.dll
WUDFRd.sys
WudfUpdate_01005.dll
the N95 should appear under "Portable Devices" in Control Panel .. device manager
good luck!
