I recently upgraded from an N80 to N95 and I had a setup on my Mac where the Mac would use my N80 using GPRS as a bluetooth model. For some reason this same setup isn't working with my newly acquired N95
All I see is
Tue Apr 24 08:31:41 2007 : Failed to open /dev/cu.Bluetooth-Modem: Resource busy
Tue Apr 24 08:32:53 2007 : Nokia 3G CID1
Tue Apr 24 08:33:03 2007 : Connect script failed
Tue Apr 24 08:33:34 2007 : Hangup (SIGHUP)
Tue Apr 24 08:33:34 2007 : tcsetattr: Interrupted system call
Tue Apr 24 08:33:49 2007 : Hangup (SIGHUP)
Tue Apr 24 08:33:59 2007 : Nokia 3G CID1
Tue Apr 24 08:34:09 2007 : Connect script failed
Tue Apr 24 08:35:04 2007 : Hangup (SIGHUP)
Tue Apr 24 08:35:04 2007 : tcsetattr: Interrupted system call
Tue Apr 24 08:35:34 2007 : Hangup (SIGHUP)
Tue Apr 24 08:35:46 2007 : Nokia 3G CID1
Tue Apr 24 08:35:56 2007 : Connect script failed
Tue Apr 24 08:38:33 2007 : Hangup (SIGHUP)
Tue Apr 24 08:38:33 2007 : tcsetattr: Interrupted system call
Tue Apr 24 08:38:47 2007 : Terminating on signal 15.
and the system.log shows like this
Apr 28 10:14:10 audrey configd[38]: setting hostname to "audrey.local"
Apr 28 10:14:10 audrey pppd[366]: Connection terminated.
Apr 28 10:14:10 audrey ccl[376]: CCLWrite : +++
Apr 28 10:14:13 audrey ccl[376]: CCLWrite : ATH\13
Apr 28 10:14:15 audrey ccl[376]: CCLMatched : NO CARRIER\13\10
Apr 28 10:14:15 audrey ccl[376]: CCLWrite : AT&F\13
Apr 28 10:14:15 audrey ccl[376]: CCLMatched : OK\13\10
Apr 28 10:14:38 audrey pppd[386]: pppd 2.4.2 (Apple version 233-13) started by r
oot, uid 501
Apr 28 10:14:43 audrey pppd[386]: Failed to open /dev/cu.Bluetooth-Modem: Resour
ce busy
Apr 28 10:15:52 audrey pppd[393]: pppd 2.4.2 (Apple version 233-13) started by r
oot, uid 501
Apr 28 10:15:56 audrey kernel[0]: ttyiossb00000a: mctl RS232_S_OUTPUTS failed e0
0002cd
Apr 28 10:15:56 audrey ccl[394]: Nokia 3G CID1
Apr 28 10:15:59 audrey kernel[0]: ttyiossb00000a: mctl RS232_S_OUTPUTS failed e0
0002cd
0002cd
Apr 28 10:16:02 audrey kernel[0]: ttyiossb00000a: mctl RS232_S_OUTPUTS failed e0
0002cd
Apr 28 10:16:03 audrey kernel[0]: ttyiossb00000a: mctl RS232_S_OUTPUTS failed e0
0002cd
Apr 28 10:16:06 audrey pppd[393]: Connect script failed
Apr 28 10:16:06 audrey kernel[0]: ttyiossb00000a: mctl RS232_S_OUTPUTS failed e0
0002cd
