in the internet folder there is an app called internet tel. when i use it, it says discovering services then says no services ????????? hum how do i use it and what does it do
question ?
andrew.w wrote:in the internet folder there is an app called internet tel. when i use it, it says discovering services then says no services ????????? hum how do i use it and what does it do
get a sevice like gizmo or truphoe, then you will see
And Gizmo is available on catalogs.
yep... another one to try too is sipgate
tryed truphone and it wont work 😞 it will not cnnect to my wifi network !! and gizmo aint free so il look at sipgate
well thats a rip off lol how can i get truephone 2 work
andrew.w wrote:tryed truphone and it wont work 😞 it will not cnnect to my wifi network !! and gizmo aint free so il look at sipgate
goto truphone forum and read some posts there, there is some advice how to get truphone working, like open port 5060 on your router and try changind some settings like UDP to TCP etc ...
Gizmo is free ??...how do you mean not free ??
yeah andrew... what are you on about this time! LOL
Gizmo is free, sipgate is free but only Truphone to my knowledge lets you do FREE landline calling (tho its only temporary)
