How to delete a WLAN access point?
3 replies · 5,289 views · Started 28 April 2007
Goto Tools, Settings, Connections, Access Points. Select the point you want to delete, then press options and select Delete from the menu that appears.
All done.
DavidC wrote:Goto Tools, Settings, Connections, Access Points. Select the point you want to delete, then press options and select Delete from the menu that appears.
All done.
Great! Cheers.
let me just say the the mark/mark all metaphor should apply to this but it doesn't. Somebody at Nokia needs to get their ass kicked for that. The mark/mark all metaphor should apply to all lists not just selective ones. I shouldn't have to delete each access point one by one.
