Midi in 9210
1 replies · 987 views · Started 07 January 2003
hi all
did nay one know how can i play the midi file in the 9210 as a ring tone ??
is the 9210 support the midi file or not if yes wich programe it will help ?
thanx alot.
I just typed midi in the search section, and the results are:
http://www.allaboutsymbian.com/phpBB2/search.php?mode=results
Anyhow, MIDI are not supported, but you can convert midi to wav, and it is free afterall
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=6064&highlight=midi
Good Luck.
BTW. You haveto register, in order to see the atached converter 😉
