Few questions
2 replies · 1,585 views · Started 29 April 2007
Hi, people i have jsut got a nokia n95 and its my first symbian absed phone.
i was wondering if any1 knew the answers to a few problems i have.
1)I would like to copy some of the 'start; menu shortcuts to another folder. IS this possible? i have feexplorer but can't see the location of the start menu items there and u can only move them via the menu system.
2)is it possible to use the camera light asa flashlight? if so i assume i need a third party program if so does any1 know of one?
3)Is it possible to have message reports (u get a text message saying the message you sent was delivered successfully) permanently on rather than saying to send them with each text message sent?
4)I don't have any WLAN's and have turned that functionality off. However, on the mains creen it still says WLAN scanning Off . Is there anyway to remove this? I would assume i need to edit the theme? If so how do i do this?
Many thanks for your time i appreciate any help.
1: You can move them around in the menu itself. Just hit "Options" when an icon is selected, and choose the appropriate entry from the list.
3: Yes, if your network supports it. In the "Messaging" app, hit "Options", choose "Settings" | "Text message" and change "Receive report" to "Yes".
4: Only by disabling the whole active standby feature: menu | Settings | General | Personalisation | Standby mode | Active standby | Off
