Product Code + Insurance
4 replies · 2,325 views · Started 30 April 2007
I know changing the product code voids the warranty, but if i change the product code, then in a few months I need the phone repairing becuase I broke the LCD or damaged it in some way then would the insurance be void too?
If you're worried about it and you end up breaking it, can't you just tell them it fell out of your pocket and you've lost it?
if you change the product code back again i can't see that they'd be able to tell 😊
change product code > upgrade firmware > change back.
if you've changed the product code and the firmware bricks it, chances are sending it back that no one will pick up on it. besides, if it is bricked - how will they tell what the product code is 😉
