N80 - connecting to internet via bluetooth
4 replies · 2,073 views · Started 30 April 2007
hi
i was just wondering if anybody can tell me, if i can connect to internet on my nokia N80ie via bluetooth with my laptop's broadband internet connection.
please help!!
saroop
you could use the bluetooth on your laptop to connect to your N80 which would become the dialler for your connection yeah... but it wont be broadband
I think you ask the opposite... If is the case, only with Gnubox project, if it works well.
if you want to connect to the net using the broadband of your laptop that doesnt really make sense to me. Why? Why not just use the laptop??? :con?
This used to be done with GNUBOX and mRouter in other models of Nokia but not with N80.
May be you can try buying a USB WiFi adapter for your LAPTOP/PC and share the broadband using a Proxy Setup.
