Fring on N95 Vodafone UK
1 replies · 3,917 views · Started 01 May 2007
I have installed this application to my Vodafone N95. I must confess I have never used this before so I have a few questions:
1. When I connect to Fring i get a Billable Events notification. If I click 'Yes' then am I charged for any calls I make?
2. When in Fring and im connected via Wifi is there any charge at all for making a GSM call to somebody on another mobile on another network?
3. Does this application even work properly on Vodafone? I have heard the Vodafone N95 had something removed which stopped apps of this nature even working at all.
4. I guess im just wondering whether making calls using Fring will incur me a massive bill somewhere down the line.
I have been on the Fring site but obviously they are saying everything is free which makes me a bit sceptical. I am just not sure it can be....Any info appreciated.
Depends on your access point - you are just sending data over the internet. If you are using 3G or GPRS you will incur data charges per your contract. If your access point is through a WLAN its free.
