hi i got nokia6630 and i forgot my lock code and now i am unable to use it please help me how i an unlock my phone.Thanks
plz help me to unlock my mobile
Only on Nokia Service they can help you!
nj7 wrote:Only on Nokia Service they can help you!
zahidchampion wrote:hi i got nokia6630 and i forgot my lock code and now i am unable to use it please help me how i an unlock my phone.Thanks
Anyway i paste this from other site. Hope its finally helping u.
THE NOKIA PHONE-LOCK RESET
Q. What is a Phone Lock?
Answer: From Nokia's webpage:
"The Phone Lock prevents your phone data from being accessed if
Your phone is stolen.
"The lock code is a number that prevents unauthorized persons from
Using your phone. These control codes are for your protection."
What is THE-NOKIA-UNLOCK:
The program exploits a design flaw in the nokia mobile phones to remove
The Phone Lock protection.
The program was tested on Nokia 6630 and Nokia 6680. The program
Should work on any other Symbian based mobile phones (including Sony
Ericson and all modern nokia phones and many others).
This tool does not remove the sim-lock.
How to use:
You need two mobile phones.
1) Do _not_ turn off the mobile phone!
2) Remove the Memory Card (MMC) from the locked phone and put it into a
second mobile. Install FExplorer on the second mobile phone. Create
the directory E:\System\Recogs and copy the-nokia-unlock.mdl into
this directory.
3) Remove the Memory Card and place it into the locked phone.
The THE-NOKIA-UNLOCK program should start after 120 seconds.
4) Remove the battery. Remove the MMC. Put the battery back and restart.
The Phone Lock has been reset to "12345".
Why does this work?
The Phone Lock disables the key pad, Bluetooth and the USB port. This
makes it impossible to access the data stored on the device without
knowing the correct code.
Nevertheless the MMC is not disabled. Nokia's OS has a lot of undocumented
features. One of them are 'recognizer' that can be used to execute a
program when the phone boots.
A recognizer is loaded and executed when a drive is mounted. The MMC
is mounted when it is placed into the mobile phone _even_ when the phone
is locked.
THE-NOKIA-UNLOCK is a recognizer that implementes yet another undocumented
feature to perform a hard reset (by software) on the phone.
Note: The same recognizer-autostart method can be used to quickly install
a backdoor on a locked mobile phone or to propagate a virus: Get in, Get
Out, Get Away.
(oh im sorrry i cant use html link)
i will update imgae soon
If it is a network unlock code, simply get it here http://www.unlocking4free.com/.
This is the unlocking site which provides the unlocking service at free of cost.visit for more details.
