Text messaging folder
1 replies · 1,915 views · Started 02 May 2007
I want to delete my text messaging folder on drive C but I cant find it like I use to browse my phone using FExplorer on my Nokia 7610 C:\System\Mail
Which folder should I delete in drive C whenever I want to change Text messaging folder from phone memory to memory card the phone will ask me if I want to copy and erase the original
Thank you
The folder/directory is under c:\private and not visible to unprivileged apps (including the built-in file manager on the phone).
The privilege needed is the so called AllFiles capability, which is not something just any app gets (and in particular file managers don't).
If you move the messages to the memory card using the Messaging app, it should remove/delete the messages from phone memory and in essence accomplish what you wish.
