Missed Calls/TomTom
3 replies · 2,803 views · Started 02 May 2007
Hi Everyone
Just wondered if anybody knows how to delete the missed calls on the P990i
Also does anyone know if Tom Tom Mobile 5.2 or 6 will work on the P990i as my pervious phone the N70 had TTM 5.2
To delete your missed calls do the following in flip open mode (phone says entries can't be deleted in fc mode even though the option is in the menu :con? )
> open main menu
> open phone
> open call log
> select missed call tab
> open the drop down menu (top of screen)
> tap on edit
> tap on the delete item of choice.
Tomtom 6 runs great on P990i (I use a Holox BT-321 bluetooth GPS), even if the official site says that only the W950i is supported.
Adam
Hi Adam.
Thanks for the reply.....
The tom tom your running on you P990i what type is as i have got V6 and its only showing .sis file which im guessing is for nokia? it as all the maps etc on there, but im not sure if the would work on P990i
Lee
Lee,
UIQ uses .sis installation files as well. I believe the UIQ version is only officially available on the DVD version of TomTom but give the file you have a try. If it's the wrong version you'll just get an error message and installation will fail. I've got UIQ and S60 installers mixed up in the past and it's never caused a problem.
Adam
