N95 FW : - I say, I say, I say ...
5 replies · 1,815 views · Started 03 May 2007
0534841 EURO1 = Sand
0536062 EURO1 = Plum
Don't really suppose which code you use though as the case colour has nothing to do with the firmware!
Maybe it was to do with the default Theme or something.
Makes you wonder why they'd go to the trouble - assuming that is, that there's even any difference between them.
Pheonix SZ wrote:... what's the difference between : -
0534841 EURO1
- and -
0536062 EURO1 ?
Anybody know ?
When you do a FW flash using Phoenix or NSU, there's only really 3 files of importance.
1. The main firmware (typically 30-40Mb) - same file is used with every product code and variant
2. The Language Variant (typically >10Mb) - T9 dictionaries, fonts, etc. - varies by region/country
3. The User File Variant (typically <10Mb) - network branding e.g. MENU/GUI - additional apps bundled by the network, disabled functionality -like VOIP, etc.
There's a few other variant file types but in most cases it's only the 3 listed above that are downloaded for OTA updates with NSU (in my experience).
