N70 Keypad Lock Code
12 replies · 17,399 views · Started 05 May 2007
hi. i am a owner of a Nokia N70. and i have a question: is there any method to remove that lock code. i use keypad autolock and is driving me crazy everytime to input that lock code when i am unlocking the keypad? is there anyone to keep the autolock but without the lock code? thanks
Search for an app called AutoLock. It's freeware and it loks the keypad without lock code.
I don't think you read the message correctly Ratza. He already has AutoLock but he wants to be able to unlock without using the unlock code! 🙄
Rather like unlocking a door without the key; impossible.
The idea of the code SoRiNuS is to stop you entering key strokes accidentally while the phone is in your pocket. It will only unlock if you enter a certain sequence of keys within a short time. So the code is a requirement.
I don't think there is any way around it.
Ken, I'm locking my keypad with left softkey and * key. I don't see where the lock code appears. The autolock period which Sorinus refers at can be found in Settings -> Security ...
yes ...i am using the autolock from settings.. i installed the application named autolock but from unknown reason i cant set the time for autolock...
SoRiNuS wrote:hi. i am a owner of a Nokia N70. and i have a question: is there any method to remove that lock code. i use keypad autolock and is driving me crazy everytime to input that lock code when i am unlocking the keypad? is there anyone to keep the autolock but without the lock code? thanks
Obviously I have misunderstood Sorinus. Sorry.
But how can you keep autolock and not have an unlock code? Perhaps it would be possible to have a short unlock code, like two keys only
Yes I see the unlock period which you can set to x minutes. But if Sorinus wants the phone to lock after x minutes then how can he unlock it WITHOUT a code? If he could do that it wouldn't be locked would it?
Or am I missing the point here?
that autolock option if for autolocking the keypad..i want that option but without that lock code..u understand me know ken? 😊anyway nevermind because that problem is solved with an application...my english sucks..srry 😊 ... thnaks ratza
Glad the prob is solved. Nokia must be crazy by making the autolock require the main code. Why couldn't they make it require Left Soft Key+Star?
cheers
KenBruce wrote:Why couldn't they make it require Left Soft Key+Star?
cheers
They probably left the opportunity for devlopers to make some cash on this issue. Lucky that there are some free apps for this. Anyway, the autolock option with lock code needed is very usefull, especially when you have many private data. My brother uses alot this function. When the phone is in locked state, a big key will appear on your display.
samueldips wrote:hey... i'm havin the sam prblm.. can u tell wat sf u used nd wher u can get it
What's wrong with your keyboard? The software is called autolock and you can search for it on AAS site or on my-symbian.com
