asphalt doesn't run on N72
4 replies · 1,850 views · Started 05 May 2007
Hi everybody,
i am recently having n72 with 1 GB memory card
i installed asphalt GT (1) on my mobile>> the game works fine but when i select "options" from main menu the application closes down with error "Memory low:close some applications"
i have all my applications installed on my memory card and there is 16 MB free space on my C: drive even then the problem persist.even though no application running in background..
Is it problem with the game OR n72 system??
please help me on this matter...😊
You got that error message because tha RAM went low. Anyway, as far as I remember, Asphalt GT was a game designed for N-Gage.
Wirelessly posted (Mozilla/4.0 (compatible; MSIE 6.0; Symbian OS; Nokia N70/5.0706.4.0.1; 9424) Opera 8.65 [en])
i know that it was made for n-gage .but n72 is higher than n-gage .is there any way out of this problem
N72 has higher specs, but the hardware is totaly different. N-Gage games are ment to be played only on N-Gage.
Have you tried Urban GT2?
Try to used DevMan to close all programs when playing games. But after you have to click it again so that you can receive sms. During activation you cannot receive sms.
If possible do not install applications that go directly to your C:/ like anitvirus, smartsetting and other system applications.
Did you say you installed your Urban GT1 on your mobile? Or just not literally speaking? if you did transfer it to your MMC card. Do not install applications on your C:/ if possible (since most antivirus will be installed in C:/) 😊
