hi
i just got a phone off ebay which was locked to uk tmobile, i needed it unlocked as im on o2.
apparently, the seller contacted tmobile who told him that it would take 1-2 weeks and cost �15 - does that sound right? what info do you need to give them? do they not need to give you a code or something?
The price is about right but not sure it will gonna take 1-2 weeks though (seems a bit long).
but how does unlocking for BB5 phones work?
can it be done over the air, or does the network always have to issue an unlock code (the ones you type in)?
if the latter, how do they get the codes - do they have to go back to nokia or can they generate them instantly?
If you need an unlocking code, simply get the code here http://www.onlinegsmunlock.com/nokia-n73/rs7wp9/ .This site helps you to unlock your mobile easily..
Its not like that you can try this way man, just get this site http://www.superunlockcodes.com/ to unlock your mobile. Also you can get the unlocking codes for all branded mobiles in this site.
