N80 - Disable the flashlight when recording video
7 replies · 3,291 views · Started 07 May 2007
I am using N80ie with firmware v 4.632.0.38
i am able to disable the flashlight on Image mode but not under video mode. Any setting or software can disable the flashlight while recording video? Please advise. Many thanks
I aware there is some 'bugs' with the current firmware 4.70++ so not intend to upgrade the buggy version until workable version available.
not exactly for stealth filming just wondering if can disable the flash (as the led will drawn additional power from battery)
owentch wrote:I aware there is some 'bugs' with the current firmware 4.70++ so not intend to upgrade the buggy version until workable version available.
IMHO theres more bugs in the other versions of f/w than this one!
