Why album images cannot be viewed in the Music Player ?
6 replies · 2,943 views · Started 07 May 2007
Hi I just bought the phone 2 days ago and found out that the album images of the songs in the music player doesnt show .. what is the pronlem exactly ? because my older nokia 6680 was showing those images in the music player .. thanx 😊
They show up just fine for me. Mine are embedded in the mp3 files, not just images in the album folder...
If you go to the 'album' or 'song' in Music Player on your N95, you can assign the album art from your images folder - Options>Album art>Options>Change...
What I did was dump the tracks on the N95 from iTunes (on a Mac) and then from google place the album art image (200x200) in my images folder. Once I'd done that I went to Music Player on the phone and assigned the artwork.
Having done all that (which is not that much really) I used Y-Browser to hide the album art from the images folder so it didn't get in the way of my holiday snaps...
Hope that helps..?
thanx jimwilx1 u really did helped me .. 1 more question if u dont mind .. after i assigned an album image to the mp3 then i deleted the image i used from the studio will the image get deleted from the mp3 file or not ?
Yes, deleting the image also deletes from the mp3 (it is only associated with the image, assigning an image to an mp3 makes no changes to the mp3 itself)
ktabic wrote:Yes, deleting the image also deletes from the mp3 (it is only associated with the image, assigning an image to an mp3 makes no changes to the mp3 itself)
No they dont I just tried that they wont get deleted :icon14:
