How do you play play list with Oggplay
4 replies · 2,725 views · Started 07 May 2007
Hi All
Switched to Oggplay when Media player stopped recognizing my play lists!
Oggplay sees all my play lists and the files within each.
But can not work out how to play the play list!
Can play the files within the play list but not the whole play list!
Any idea?
Vim
I don�t know if I understand the problem...:frown: But Oggplay is a easy to use player with few options. Play with it for a while and you find a way.
Vim
Go to Playlists, select (highlight) the playlist which you want to play and press the hotkey assigned to play. Hotkeys can be assigned through Options menu. It will not work if you select it with the joystick.
nj7 & Ratza
Thanks for the reply.
Using a N72 with version 1.69 Unstable build 0s7.0 mmf
Hotskeys as below
5 Pause/Play
2 Play
On selecting the playlist and pressing either 5 or 2 it take me to the list of files within the playlist and does not play.
If I press 2, 5 or the joystick then Ogg will play the file.
Any ideas?
Vim
