Hi all, anyone using CoPilot with the N95? I've noticed it is supported but I can't ascertain if it uses the built in GPS or if you need an external receiver? Also what package do you need to purchase as there seems to be so many options and I don't want to pay for something I won't use!
Finally, is it worth it? Is it a lot better than the Nokia solution I already have?
