Hi all,
I am new to this forum so please excuse me if i sound like a total NOOB!!
Basically i am using a N70 with Tomtom 5 atm with separate reciever and just ordered myself a nokia N95.
My question is will i be able to use the same tomtom software from the memory card out of my N70 for the N95?
At the moment the N70 works a treat but the built-in gps reciever made me buy the N95.
I understand the N95 has its own Gps maps but i find that Tomtom is the easiest to use and will save me downloading new maps ect.
Please let me know!
I dont think the N70 tomtom will work on the N95 because N70 is S60v2 and N95 is S60v3 and they are incompatible.
If you get a different tomtom software that will work but currently only with your Bluetooth GPS as the integrated GPS isnt supported by TomTom yet
As srw985 is saying; the TT5 software isn't compatible with S60 3rd. TT6 are but does not have support for built in GPS (only in Windows Mobile version).
Thanks for the reply guys!
superswede wrote:As srw985 is saying; the TT5 software isn't compatible with S60 3rd. TT6 are but does not have support for built in GPS (only in Windows Mobile version).
There is a rumour that TomTom is currently working on a version that supports Nokia's devices with internal GPS. But it is only a rumour at the moment.
