Hi all.
Im a new user to the Symbian phones !
i own a Nokia N95 with the latest firmware wich i downloded in Sweden.
i have a couple of questions, mostly about softwares
1: Wich is the rekomended software to use for voice rekording during a phone call, without the Beep all the time ? and where to download ? "i need it for work"
2: Where can i download Msn Messenger to use it in my phone ? and how to use it ?
3: How can i watch mpeg and avi movies ? and other formats hopefully ? is there any program that you rekoemnend? and where to download it
4: Should i use a Firewall ? if there is such software ? and should i use an antivirus ? i have F-Secure !
5: is there any better batteri to buy, original from Nokia itself wich is better that the one we get in the phone ?
THanks in advance 😊
Eclipse wrote:Hi all.
i have a couple of questions, mostly about softwares1: Wich is the rekomended software to use for voice rekording during a phone call, without the Beep all the time ? and where to download ? "i need it for work"
THanks in advance 😊
1. dont think you can i think its got to do with the other party on the call so that they know you are recording them i believe there is software that can get round this!
2.there is software just google
3.smartmovie:icon13: or super:icon14: super is very good and you can play your vids in realplayer
4.unless you are putting hacked or untrusted software on your phone you should not need a firewall or anti-virus
5.cheap non original batteries are crap and can be a problem....i know nokia batteries are expensive.....but you pay for what you get...i bought a lighttel battery in egypt for my n80 it died in 8 hours despite having the same specs as my original 860 mhah nokia which would last a day and a half!
hope this helps you
THx Jim115 😊
*Oki can some one plz rekomend me a good call voice recorder ?
*Any link where i can download the Msn messenger ? i googled and found other programs wich is for multi messiging! isnt there a microsoft msn messenger version for symbian phone ?
*Wich antivirus ? And wich Firewall do you guys rekoemnd ?is there a combind one ?
* Where can i find the Super player Jum 115 Talked about ? can it play movies without converting them ? i mean directly in the phone ? or do i have to convert every single movie in windows and then put them in the phone ? !
Excuse my noob questions :frown:
