How do u get the sat nav to work?
1 replies · 2,006 views · Started 08 May 2007
i cant figure how the sat navs works?
it says settings are wrong, its on orange 😊 😊 😊 😊 😊
kulveer wrote:i cant figure how the sat navs works?
Need more detail are you sure you have the Map appliaction setup to use internal GPS antenna.
Check Tools / Settings / General / Positioning / Positioning Methods / Check Integrated GPS is ticked
Also have you loaded the Maps onto the Phone or are you just going to download them. Make sure in maps / settings that if your going to download the maps that its network connection is enabled though this will cost you money your better using Maploader to load them on for free.
