using keypad with games?
3 replies · 2,251 views · Started 08 January 2003
How it's designed to use keypad with games in 3650? Which button we press to go left in games? Are they same as normal keypad(2,5,8,0)?
i guess we'll never know until we see the machine and can play games on it - unless someone's tried the phone?
There's a joystick, using that is better. 😊
But i was wondering, if they're both series 60 devices (the 7650 and 3650) then we play games from the 7650 on the 3650, they keys that are used for movement (numbers) on the 7650 are 4, 2,6,8 would they be the same on the 3650? That would be pretty akward :-?
[quote="😊"]There's a joystick, using that is better. 😊
But i was wondering, if they're both series 60 devices (the 7650 and 3650) then we play games from the 7650 on the 3650, they keys that are used for movement (numbers) on the 7650 are 4, 2,6,8 would they be the same on the 3650? That would be pretty akward :-?[/quote]
The best solution will be if the game makers add an option to their products for the user to customize the ingame keys.
