Looking for a better audio-player
0 replies · 2,402 views · Started 09 May 2007
Hello,
I'm using my nokia 5500 to listen to podcasts of radio shows. It's typically rather lengthy audio clips, often close to an hour each. My problem is that the built-in audio-player looses track of where in a file it was when it's switched off, which is what happens as soon as I plug in the USB cable. And even if I do remember roughly where I was it's rather awkward to fast-forward through the file to a given offset.
Can anyone recommend an audio-player better suited to my needs?
