Hello,
Are there utilities to test the performances of N73 (memory and MiniSD memory)
Thanks 😊
Hello,
Thanks 😊
To test...Jbenchmark, java application, maybe is what you want.
I have just seen this program but I cannot test it one needs a login
and password.
What I will want is to test the speed of the mini SD card simply 😉
miniSD card is easy. There is a lot of free software for that on Net, for PC + card reader. Just googlit, and you find.
ok, but the test is make by PC through a card reader
Yes, but is the same. You obtain a card benchmark.
what is your speed with your card in fat16 OR 32 ?
I don�t know. I never had made a measure. I just use a Sandisk UltraII card, and that�s all.
ok, thank you very much for your information 😉
