No com ports in mRouter : FIXED
3 replies · 2,067 views · Started 08 January 2003
I posted a topic on here a while back cause I was having the problem above. No com ports were showing in mRouter.
It turns out that my modem appears to be preventing it from working, if I disable my modem then I am able to see the com ports yay 😊
I thought this may be of use to some people out there, as I had seen at least one other person with the same problem.
yeah... i do remeber fiddling with Mrouter and the ports stuff before getting PC suite to work..
But i can't remeber how!!! 😮
[quote="The Unquenshable"]Even more simply, all I have to do is install the bluetooth device before my modem, then they can both work happily together.[/quote]
Hhmmmmmm....interesting......maybe I'll try this.....
My <router thingy keeps looking for a Com0.......but there is no Com0, maybe if I un-install the modem, then add the blue-tooth, then the modem back, it may just work......
